Good morning
Mistake was made during transaction intended for data purchase on 07066602641. #15000 was selected instead of #1500 from First bank, so this resulted in the...
Hi Chinemerem, MTN only reverses excess recharge to bank account that is from N20000 and above; however, if you have not used the data, you can contact MTN support for them to...
Hi Diana, To Reset your PIN- dial *321#; *600#; or *777#, select option 1 for Airtime Share, Select option 3 to Reset PIN, enter your mother's maiden name, enter your Date of...
Hi Taiwo. sorry for the wrong data activation. you can contact MTN support, they will convert the data to Airtime for you if the data is not in use.
You can contact MTN...
