Hello I normally use your Smart Data menu for daily data plans, especially the ₦100/₦200/₦300 options. But today, I noticed only the ₦1000 for 4.5GB and multi-day options are...
The 1TB yearly plan for N100k looks like something that would work perfectly well for my needs but I don't know if it will work on the official MTN router.
Are MTN Router...
According to the plan, I am entitled to 5gb daily until the 30-day duration for the plan expires after the initial 80gb
But today makes it just the 21st day since I purchased...
I'm on Betatalk tariff plan, and you know that give #300 airtime bonus per #100 recharge.
I recharged #500 airtime this morning, and I was credited with #1500 airtime bonus...
Hi Precious, MTN Betatalk bonus can be used for browsing, but when you have active data bundle, they are not supposed to charge you from your bonus but from your data.
However...
