Second option is, we will assist you from here when you are able to provide the registration and usage details of your line
You will be assisted with the puk if you are able...
My MTN Sim card is blocked and asking for the PUK. I misplaced the Sim pack so getting from there is virtually impossible. Pls help me recover it my number is 09130793443. Regards.
I used code for my MTN line,on process to open the line ,when my phone was fall. I mistake put wrong number, My sim was blocked.pls I need my puk number. This my number...
