Checks on your line show that the name provided above does not tally with the one on your sim, however you may need to visit our office with your VNIN to update the sim...
On my MIFI Modem, when I click on device sms, the user interphase does not come.
It says waiting and keeps rolling and nothing happens.
I will have to force shut down and...
I need to restart (switch Off/On) the Hynetflex router. Using the on/off swich at the back does not work because of the battery backup inside the device, Any advise is...
Hi. Sorry about your Hynetflex router issue. You can write MTN on Facebook or other channels for help. For Facebook, it's MTNLoaded and WhatsApp, 09033000001. Other contact...
