Hi Kwoopnaan, check if your message box is filled up, you can delete unwanted messages, if the issue persist, you need to check if you have active Do Not Disturb (DND) service...
I am a sim registration agent7/ client , i register and sell mtn sim card upto 100 sims on daily basis, basically that is what i do as a job that i feed with. I will be happy as...
Connect to your Mifi
On your browser, type 192.168.0.1 and enter
If you have your log in details already, log in with them and if you don't check the default log in details...
Checks on your line show that the name provided above does not tally with the one on your sim, however you may need to visit our office with your VNIN to update the sim...
