I experienced a similar problem, and during my search, I came across a Quora suggestion advising that you connect your MiFi to your laptop using a USB cable just like you would...
My mobile mifi has a problem.
The Wi-Fi keeps disabling itself on the web browser it would say successful but its still disabled, I think it's a software issue how do I fix it...
ANSWER
Visit the address http://mtnbroadband.ng/index.html
username: admin
password: admin
Click Quick Settings on the Dashboard
Change the Network Name(SSID) to any...
