Please view details below
Requirements for Proxy SIM Swap Service.
NB:
• A customer can only authorize a proxy swap request on their line
• Customer and Proxy NIN must...
Kindly use the below details to correct the message center number of your line.
On your phone, kindly visit your message settings, select SMS or Text Messages, then choose...
You can retrieve your NIN by dialing *346# on the phone number you registered with and it will cost you N20. To link your NIN, please dial *785# and select 1
Hi Sulyman, it is likely that the SIM has gotten damaged, try and insert the SIM in another phone possibly a small phone, if the issue persist, you will need to do SIM swap...
